Moin,
nach dem Update auf Libre Workspace 0.10.2 kann ich mit Apps, die OpenID Connect für den Login verwenden, nicht mehr auf portal.DOMAIN/openid/userinfo zugreifen.
Folgenden Logeintrag bekomme ich:
Sep 04 11:10:39 la libre-workspace-portal[63359]: WARNING:django.request:Not Found: /('https:/portal.DOMAIN/openid/userinfo',)
Habe auch schon einen Bug report im Github Repository erstellt:
opened 09:37AM - 04 Sep 25 UTC
**Describe the bug/problem**
After the upgrade to 0.10.2 can't apps – which use… OpenID Connect to manage logins – fetch the userinfo endpoint. This prevents the login via OIDC.
**To Reproduce**
Steps to reproduce the behavior:
1. Upgrade to latest (at time of writing: 0.10.2)
2. Open an app which uses OIDC for logins
3. Try to log into an OIDC-linked account
4. See error
**Logfile**
<details>
<summary>
System Log for `libre-workspace-portal.service`:
</summary>
Sep 04 11:09:24 la libre-workspace-portal[63351]: [2025-09-04 11:09:24 +0200] [63351] [INFO] Listening at: http://127.0.0.1:11123 (63351)
Sep 04 11:09:24 la libre-workspace-portal[63351]: [2025-09-04 11:09:24 +0200] [63351] [INFO] Using worker: sync
Sep 04 11:09:24 la libre-workspace-portal[63352]: [2025-09-04 11:09:24 +0200] [63352] [INFO] Booting worker with pid: 63352
Sep 04 11:09:24 la libre-workspace-portal[63355]: [2025-09-04 11:09:24 +0200] [63355] [INFO] Booting worker with pid: 63355
Sep 04 11:09:24 la libre-workspace-portal[63356]: [2025-09-04 11:09:24 +0200] [63356] [INFO] Booting worker with pid: 63356
Sep 04 11:09:24 la libre-workspace-portal[63358]: [2025-09-04 11:09:24 +0200] [63358] [INFO] Booting worker with pid: 63358
Sep 04 11:09:24 la libre-workspace-portal[63359]: [2025-09-04 11:09:24 +0200] [63359] [INFO] Booting worker with pid: 63359
Sep 04 11:10:39 la libre-workspace-portal[63359]: WARNING:django.request:Not Found: /('https:/portal.gelbphoenix.de/openid/userinfo',)
</details>
<details>
<summary>
System Log for Autocaliweb (App I tested this with):
</summary>
[2025-09-04 11:10:39,370] ERROR {oauth_bb.py:382} Failed to fetch user info from Generic OAuth:
<!doctype html>
<html lang="en">
<head>
<title>Not Found</title>
</head>
<body>
<h1>Not Found</h1><p>The requested resource was not found on this server.</p>
</body>
</html>
</details>
**Expected behavior**
The User should be logged in.
**Environment (please complete the following information):**
- Libre Workspace version: 0.10.2
- Hardware: Hetzner CX42
