Ich habe gerade versucht das Mailcow Addon aus dem Portal zu installieren und das sind die letzten Fehler des Installationsprozesses:
Feb 20 09:35:19 la libre-workspace-portal[3993412]: Error response from daemon: driver failed programming external connectivity on endpoint mailcow-nginx-mailcow-1 (c1534e984150fb70f9e11acda062ca5d07272274157c3379c05a90190ca83a0d): Error starting userland proxy: listen tcp4 0.0.0.0:443: bind: address already in use
Deswegen startet Mailcow natürlich nicht.
Gibt es eine möglichkeit wie ich das umgehen kann?
Es ist die docker-compose.yml aus dem Addon.
unbound-mailcow:
image: ghcr.io/mailcow/unbound:1.24
- TZ=${TZ}
- SKIP_UNBOUND_HEALTHCHECK=${SKIP_UNBOUND_HEALTHCHECK:-n}
- ./data/hooks/unbound:/hooks:Z
- ./data/conf/unbound/unbound.conf:/etc/unbound/unbound.conf:ro,Z
restart: always
tty: true
networks:
mailcow-network:
ipv4_address: ${IPV4_NETWORK:-172.22.1}.254
aliases:
- unbound
mysql-mailcow:
image: mariadb:10.11
depends_on:
- unbound-mailcow
- netfilter-mailcow
stop_grace_period: 45s
- mysql-vol-1:/var/lib/mysql/
- mysql-socket-vol-1:/var/run/mysqld/:z
- ./data/conf/mysql/:/etc/mysql/conf.d/:ro,Z
- TZ=${TZ}
- MYSQL_ROOT_PASSWORD=${DBROOT}
- MYSQL_DATABASE=${DBNAME}
- MYSQL_USER=${DBUSER}
- MYSQL_PASSWORD=${DBPASS}
- MYSQL_INITDB_SKIP_TZINFO=1
restart: always
- "${SQL_PORT:-127.0.0.1:13306}:3306"
networks:
mailcow-network:
aliases:
- mysql
redis-mailcow:
image: redis:7.4.6-alpine
entrypoint: ["/bin/sh","/redis-conf.sh"]
- redis-vol-1:/data/
- ./data/conf/redis/redis-conf.sh:/redis-conf.sh:z
restart: always
depends_on:
- netfilter-mailcow
- "${REDIS_PORT:-127.0.0.1:7654}:6379"
- TZ=${TZ}
- REDISPASS=${REDISPASS}
- REDISMASTERPASS=${REDISMASTERPASS:-}
sysctls:
- net.core.somaxconn=4096
networks:
mailcow-network:
ipv4_address: ${IPV4_NETWORK:-172.22.1}.249
aliases:
- redis
clamd-mailcow:
image: ghcr.io/mailcow/clamd:1.71
restart: always
depends_on:
unbound-mailcow:
condition: service_healthy
dns:
- ${IPV4_NETWORK:-172.22.1}.254
- TZ=${TZ}
- SKIP_CLAMD=${SKIP_CLAMD:-n}
- ./data/conf/clamav/:/etc/clamav/:Z
- clamd-db-vol-1:/var/lib/clamav
networks:
mailcow-network:
aliases:
- clamd
rspamd-mailcow:
image: ghcr.io/mailcow/rspamd:3.14.2
stop_grace_period: 30s
depends_on:
- dovecot-mailcow
- clamd-mailcow
- TZ=${TZ}
- IPV4_NETWORK=${IPV4_NETWORK:-172.22.1}
- IPV6_NETWORK=${IPV6_NETWORK:-fd4d:6169:6c63:6f77::/64}
- REDIS_SLAVEOF_IP=${REDIS_SLAVEOF_IP:-}
- REDIS_SLAVEOF_PORT=${REDIS_SLAVEOF_PORT:-}
- SPAMHAUS_DQS_KEY=${SPAMHAUS_DQS_KEY:-}
- ./data/hooks/rspamd:/hooks:Z
- ./data/conf/rspamd/custom/:/etc/rspamd/custom:z
- ./data/conf/rspamd/override.d/:/etc/rspamd/override.d:Z
- ./data/conf/rspamd/local.d/:/etc/rspamd/local.d:Z
- ./data/conf/rspamd/plugins.d/:/etc/rspamd/plugins.d:Z
- ./data/conf/rspamd/lua/:/etc/rspamd/lua/:ro,Z
- ./data/conf/rspamd/rspamd.conf.local:/etc/rspamd/rspamd.conf.local:Z
- ./data/conf/rspamd/rspamd.conf.override:/etc/rspamd/rspamd.conf.override:Z
- rspamd-vol-1:/var/lib/rspamd
restart: always
hostname: rspamd
dns:
networks:
mailcow-network:
aliases:
- rspamd
php-fpm-mailcow:
image: ghcr.io/mailcow/phpfpm:8.2.29-1
command: "php-fpm -d date.timezone=${TZ} -d expose_php=0"
depends_on:
- redis-mailcow
- ./data/hooks/phpfpm:/hooks:Z
- ./data/web:/web:z
- ./data/conf/rspamd/dynmaps:/dynmaps:ro,z
- ./data/conf/rspamd/custom/:/rspamd_custom_maps:z
- ./data/conf/dovecot/auth/mailcowauth.php:/mailcowauth/mailcowauth.php:z
- ./data/web/inc/functions.inc.php:/mailcowauth/functions.inc.php:z
- ./data/web/inc/functions.auth.inc.php:/mailcowauth/functions.auth.inc.php:z
- ./data/web/inc/sessions.inc.php:/mailcowauth/sessions.inc.php:z
- ./data/web/inc/functions.mailbox.inc.php:/mailcowauth/functions.mailbox.inc.php:z
- ./data/web/inc/functions.ratelimit.inc.php:/mailcowauth/functions.ratelimit.inc.php:z
- ./data/web/inc/functions.acl.inc.php:/mailcowauth/functions.acl.inc.php:z
- ./data/conf/sogo/:/etc/sogo/:z
- ./data/conf/rspamd/meta_exporter:/meta_exporter:ro,z
- ./data/conf/phpfpm/crons:/crons:z
- ./data/conf/phpfpm/sogo-sso/:/etc/sogo-sso/:z
- ./data/conf/phpfpm/php-fpm.d/pools.conf:/usr/local/etc/php-fpm.d/z-pools.conf:Z
- ./data/conf/phpfpm/php-conf.d/opcache-recommended.ini:/usr/local/etc/php/conf.d/opcache-recommended.ini:Z
- ./data/conf/phpfpm/php-conf.d/upload.ini:/usr/local/etc/php/conf.d/upload.ini:Z
- ./data/conf/phpfpm/php-conf.d/other.ini:/usr/local/etc/php/conf.d/zzz-other.ini:Z
- ./data/conf/dovecot/global_sieve_before:/global_sieve/before:z
- ./data/conf/dovecot/global_sieve_after:/global_sieve/after:z
- ./data/assets/templates:/tpls:z
- ./data/conf/nginx/:/etc/nginx/conf.d/:z
dns:
- LOG_LINES=${LOG_LINES:-9999}
- TZ=${TZ}
- DBNAME=${DBNAME}
- DBUSER=${DBUSER}
- DBPASS=${DBPASS}
- MAILCOW_HOSTNAME=${MAILCOW_HOSTNAME}
- MAILCOW_PASS_SCHEME=${MAILCOW_PASS_SCHEME:-BLF-CRYPT}
- IMAP_PORT=${IMAP_PORT:-143}
- IMAPS_PORT=${IMAPS_PORT:-993}
- POP_PORT=${POP_PORT:-110}
- POPS_PORT=${POPS_PORT:-995}
- SIEVE_PORT=${SIEVE_PORT:-4190}
- SUBMISSION_PORT=${SUBMISSION_PORT:-587}
- SMTPS_PORT=${SMTPS_PORT:-465}
- SMTP_PORT=${SMTP_PORT:-25}
- API_KEY=${API_KEY:-invalid}
- API_KEY_READ_ONLY=${API_KEY_READ_ONLY:-invalid}
- API_ALLOW_FROM=${API_ALLOW_FROM:-invalid}
- COMPOSE_PROJECT_NAME=${COMPOSE_PROJECT_NAME:-mailcow-dockerized}
- SKIP_FTS=${SKIP_FTS:-y}
- SKIP_OLEFY=${SKIP_OLEFY:-n}
- SKIP_SOGO=${SKIP_SOGO:-n}
- ALLOW_ADMIN_EMAIL_LOGIN=${ALLOW_ADMIN_EMAIL_LOGIN:-n}
- MASTER=${MASTER:-y}
- DEV_MODE=${DEV_MODE:-n}
- DEMO_MODE=${DEMO_MODE:-n}
- WEBAUTHN_ONLY_TRUSTED_VENDORS=${WEBAUTHN_ONLY_TRUSTED_VENDORS:-n}
- CLUSTERMODE=${CLUSTERMODE:-}
- ADDITIONAL_SERVER_NAMES=${ADDITIONAL_SERVER_NAMES:-}
restart: always
labels:
ofelia.enabled: "true"
ofelia.job-exec.phpfpm_keycloak_sync.schedule: "0 * * * * *"
ofelia.job-exec.phpfpm_keycloak_sync.no-overlap: "true"
ofelia.job-exec.phpfpm_keycloak_sync.command: "/bin/bash -c \"php /crons/keycloak-sync.php || exit 0\""
ofelia.job-exec.phpfpm_ldap_sync.schedule: "0 * * * * *"
ofelia.job-exec.phpfpm_ldap_sync.no-overlap: "true"
ofelia.job-exec.phpfpm_ldap_sync.command: "/bin/bash -c \"php /crons/ldap-sync.php || exit 0\""
networks:
mailcow-network:
aliases:
- phpfpm
sogo-mailcow:
image: ghcr.io/mailcow/sogo:5.12.4-1
- DBNAME=${DBNAME}
- DBUSER=${DBUSER}
- DBPASS=${DBPASS}
- TZ=${TZ}
- ACL_ANYONE=${ACL_ANYONE:-disallow}
- SOGO_EXPIRE_SESSION=${SOGO_EXPIRE_SESSION:-480}
- SOGO_URL_ENCRYPTION_KEY=${SOGO_URL_ENCRYPTION_KEY:-SOGoSuperSecret0}
dns:
- ./data/hooks/sogo:/hooks:Z
- ./data/web/inc/init_db.inc.php:/init_db.inc.php:z
- ./data/conf/sogo/custom-favicon.ico:/usr/lib/GNUstep/SOGo/WebServerResources/img/sogo.ico:z
- ./data/conf/sogo/custom-shortlogo.svg:/usr/lib/GNUstep/SOGo/WebServerResources/img/sogo-compact.svg:z
- ./data/conf/sogo/custom-fulllogo.svg:/usr/lib/GNUstep/SOGo/WebServerResources/img/sogo-full.svg:z
- ./data/conf/sogo/custom-fulllogo.png:/usr/lib/GNUstep/SOGo/WebServerResources/img/sogo-logo.png:z
- ./data/conf/sogo/custom-theme.js:/usr/lib/GNUstep/SOGo/WebServerResources/js/theme.js:z
- ./data/conf/sogo/custom-sogo.js:/usr/lib/GNUstep/SOGo/WebServerResources/js/custom-sogo.js:z
- sogo-web-vol-1:/sogo_web
- sogo-userdata-backup-vol-1:/sogo_backup
labels:
ofelia.job-exec.sogo_sessions.schedule: "0 * * * * *"
ofelia.job-exec.sogo_sessions.command: "/bin/bash -c \"[[ $${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-tool -v expire-sessions $${SOGO_EXPIRE_SESSION} || exit 0\""
ofelia.job-exec.sogo_ealarms.schedule: "0 * * * * *"
ofelia.job-exec.sogo_ealarms.command: "/bin/bash -c \"[[ $${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-ealarms-notify -p /etc/sogo/cron.creds || exit 0\""
ofelia.job-exec.sogo_eautoreply.schedule: "0 */5 * * * *"
ofelia.job-exec.sogo_eautoreply.command: "/bin/bash -c \"[[ $${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-tool update-autoreply -p /etc/sogo/sieve.creds || exit 0\""
ofelia.job-exec.sogo_backup.schedule: "0 0 0 * * *"
ofelia.job-exec.sogo_backup.command: "/bin/bash -c \"[[ $${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-tool backup /sogo_backup ALL || exit 0\""
restart: always
networks:
mailcow-network:
ipv4_address: ${IPV4_NETWORK:-172.22.1}.248
aliases:
- sogo
dovecot-mailcow:
image: ghcr.io/mailcow/dovecot:2.3.21.1-1
depends_on:
- mysql-mailcow
- netfilter-mailcow
- redis-mailcow
dns:
cap_add:
- NET_BIND_SERVICE
- ./data/hooks/dovecot:/hooks:Z
- ./data/conf/dovecot:/etc/dovecot:z
- ./data/assets/ssl:/etc/ssl/mail/:ro,z
- ./data/conf/phpfpm/sogo-sso/:/etc/phpfpm/:z
- vmail-vol-1:/var/vmail
- vmail-index-vol-1:/var/vmail_index
- crypt-vol-1:/mail_crypt/
- ./data/assets/templates:/templates:z
- DOVECOT_MASTER_USER=${DOVECOT_MASTER_USER:-}
- DOVECOT_MASTER_PASS=${DOVECOT_MASTER_PASS:-}
- MAILCOW_REPLICA_IP=${MAILCOW_REPLICA_IP:-}
- DOVEADM_REPLICA_PORT=${DOVEADM_REPLICA_PORT:-}
- DBNAME=${DBNAME}
- DBUSER=${DBUSER}
- DBPASS=${DBPASS}
- TZ=${TZ}
- MAILDIR_GC_TIME=${MAILDIR_GC_TIME:-7200}
- FTS_HEAP=${FTS_HEAP:-512}
- FTS_PROCS=${FTS_PROCS:-3}
- MAILDIR_SUB=${MAILDIR_SUB:-}
- "${DOVEADM_PORT:-127.0.0.1:19991}:12345"
- "${IMAP_PORT:-143}:143"
- "${IMAPS_PORT:-993}:993"
- "${POP_PORT:-110}:110"
- "${POPS_PORT:-995}:995"
- "${SIEVE_PORT:-4190}:4190"
restart: always
tty: true
labels:
ofelia.job-exec.dovecot_imapsync_runner.schedule: "0 * * * * *"
ofelia.job-exec.dovecot_imapsync_runner.no-overlap: "true"
ofelia.job-exec.dovecot_imapsync_runner.command: "/bin/bash -c \"[[ $${MASTER} == y ]] && /usr/local/bin/gosu nobody /usr/local/bin/imapsync_runner.pl || exit 0\""
ofelia.job-exec.dovecot_trim_logs.schedule: "0 * * * * *"
ofelia.job-exec.dovecot_trim_logs.command: "/bin/bash -c \"[[ $${MASTER} == y ]] && /usr/local/bin/gosu vmail /usr/local/bin/trim_logs.sh || exit 0\""
ofelia.job-exec.dovecot_quarantine.schedule: "0 */20 * * * *"
ofelia.job-exec.dovecot_quarantine.command: "/bin/bash -c \"[[ $${MASTER} == y ]] && /usr/local/bin/gosu vmail /usr/local/bin/quarantine_notify.py || exit 0\""
ofelia.job-exec.dovecot_clean_q_aged.schedule: "0 0 0 * * *"
ofelia.job-exec.dovecot_clean_q_aged.command: "/bin/bash -c \"[[ $${MASTER} == y ]] && /usr/local/bin/gosu vmail /usr/local/bin/clean_q_aged.sh || exit 0\""
ofelia.job-exec.dovecot_maildir_gc.schedule: "0 */30 * * * *"
ofelia.job-exec.dovecot_maildir_gc.command: "/bin/bash -c \"source /source_env.sh ; /usr/local/bin/gosu vmail /usr/local/bin/maildir_gc.sh\""
ofelia.job-exec.dovecot_sarules.schedule: "@every 24h"
ofelia.job-exec.dovecot_sarules.command: "/bin/bash -c \"/usr/local/bin/sa-rules.sh\""
ofelia.job-exec.dovecot_fts.schedule: "0 0 0 * * *"
ofelia.job-exec.dovecot_fts.command: "/bin/bash -c \"/usr/local/bin/gosu vmail /usr/local/bin/optimize-fts.sh\""
ofelia.job-exec.dovecot_repl_health.schedule: "0 */5 * * * *"
ofelia.job-exec.dovecot_repl_health.command: "/bin/bash -c \"/usr/local/bin/gosu vmail /usr/local/bin/repl_health.sh\""
ulimits:
nproc: 65535
nofile:
soft: 20000
hard: 40000
networks:
mailcow-network:
ipv4_address: ${IPV4_NETWORK:-172.22.1}.250
aliases:
- dovecot
postfix-mailcow:
image: ghcr.io/mailcow/postfix:3.7.11-1
depends_on:
mysql-mailcow:
condition: service_started
unbound-mailcow:
postfix-tlspol-mailcow:
- ./data/hooks/postfix:/hooks:Z
- ./data/conf/postfix:/opt/postfix/conf:z
- postfix-vol-1:/var/spool/postfix
- crypt-vol-1:/var/lib/zeyple
- TZ=${TZ}
- DBNAME=${DBNAME}
- DBUSER=${DBUSER}
- DBPASS=${DBPASS}
cap_add:
- NET_BIND_SERVICE
- "${SMTP_PORT:-25}:25"
- "${SMTPS_PORT:-465}:465"
- "${SUBMISSION_PORT:-587}:587"
restart: always
dns:
networks:
mailcow-network:
ipv4_address: ${IPV4_NETWORK:-172.22.1}.253
aliases:
- postfix
image: ghcr.io/mailcow/postfix-tlspol:1.8.22
depends_on:
unbound-mailcow:
- postfix-tlspol-vol-1:/var/lib/postfix-tlspol
- TZ=${TZ}
restart: always
dns:
networks:
mailcow-network:
aliases:
- postfix-tlspol
memcached-mailcow:
image: memcached:alpine
restart: always
- TZ=${TZ}
networks:
mailcow-network:
aliases:
- memcached
nginx-mailcow:
depends_on:
- redis-mailcow
- php-fpm-mailcow
- sogo-mailcow
- rspamd-mailcow
image: ghcr.io/mailcow/nginx:1.05
dns:
- HTTPS_PORT=${HTTPS_PORT:-443}
- HTTP_PORT=${HTTP_PORT:-80}
- TZ=${TZ}
- SKIP_RSPAMD=${SKIP_RSPAMD:-n}
- ENABLE_IPV6=${ENABLE_IPV6:-true}
- HTTP_REDIRECT=${HTTP_REDIRECT:-n}
- PHPFPMHOST=${PHPFPMHOST:-}
- SOGOHOST=${SOGOHOST:-}
- RSPAMDHOST=${RSPAMDHOST:-}
- REDISHOST=${REDISHOST:-}
- NGINX_USE_PROXY_PROTOCOL=${NGINX_USE_PROXY_PROTOCOL:-n}
- TRUSTED_PROXIES=${TRUSTED_PROXIES:-}
- ./data/web:/web:ro,z
- ./data/assets/ssl/:/etc/ssl/mail/:ro,z
- sogo-web-vol-1:/usr/lib/GNUstep/SOGo/
- "${HTTPS_BIND:-}:${HTTPS_PORT:-443}:${HTTPS_PORT:-443}"
- "${HTTP_BIND:-}:${HTTP_PORT:-80}:${HTTP_PORT:-80}"
restart: always
networks:
mailcow-network:
aliases:
- nginx
acme-mailcow:
depends_on:
nginx-mailcow:
unbound-mailcow:
image: ghcr.io/mailcow/acme:1.95
dns:
- ADDITIONAL_SAN=${ADDITIONAL_SAN}
- AUTODISCOVER_SAN=${AUTODISCOVER_SAN:-y}
- DBNAME=${DBNAME}
- DBUSER=${DBUSER}
- DBPASS=${DBPASS}
- SKIP_LETS_ENCRYPT=${SKIP_LETS_ENCRYPT:-n}
- DIRECTORY_URL=${DIRECTORY_URL:-}
- ENABLE_SSL_SNI=${ENABLE_SSL_SNI:-n}
- SKIP_IP_CHECK=${SKIP_IP_CHECK:-n}
- SKIP_HTTP_VERIFICATION=${SKIP_HTTP_VERIFICATION:-n}
- ONLY_MAILCOW_HOSTNAME=${ONLY_MAILCOW_HOSTNAME:-n}
- LE_STAGING=${LE_STAGING:-n}
- TZ=${TZ}
- SNAT_TO_SOURCE=${SNAT_TO_SOURCE:-n}
- SNAT6_TO_SOURCE=${SNAT6_TO_SOURCE:-n}
- ./data/web/.well-known/acme-challenge:/var/www/acme:z
- ./data/assets/ssl:/var/lib/acme/:z
- ./data/assets/ssl-example:/var/lib/ssl-example/:ro,Z
restart: always
networks:
mailcow-network:
aliases:
- acme
netfilter-mailcow:
image: ghcr.io/mailcow/netfilter:1.63
restart: always
privileged: true
- TZ=${TZ}
- DISABLE_NETFILTER_ISOLATION_RULE=${DISABLE_NETFILTER_ISOLATION_RULE:-n}
network_mode: "host"
- /lib/modules:/lib/modules:ro
watchdog-mailcow:
image: ghcr.io/mailcow/watchdog:2.09
dns:
tmpfs:
- /tmp
restart: always
depends_on:
- postfix-mailcow
- dovecot-mailcow
- mysql-mailcow
- acme-mailcow
- redis-mailcow
- TZ=${TZ}
- DBNAME=${DBNAME}
- DBUSER=${DBUSER}
- DBPASS=${DBPASS}
- DBROOT=${DBROOT}
- USE_WATCHDOG=${USE_WATCHDOG:-n}
- WATCHDOG_NOTIFY_EMAIL=${WATCHDOG_NOTIFY_EMAIL:-}
- WATCHDOG_NOTIFY_BAN=${WATCHDOG_NOTIFY_BAN:-y}
- WATCHDOG_NOTIFY_START=${WATCHDOG_NOTIFY_START:-y}
- WATCHDOG_SUBJECT=${WATCHDOG_SUBJECT:-Watchdog ALERT}
- WATCHDOG_NOTIFY_WEBHOOK=${WATCHDOG_NOTIFY_WEBHOOK:-}
- WATCHDOG_NOTIFY_WEBHOOK_BODY=${WATCHDOG_NOTIFY_WEBHOOK_BODY:-}
- WATCHDOG_EXTERNAL_CHECKS=${WATCHDOG_EXTERNAL_CHECKS:-n}
- WATCHDOG_MYSQL_REPLICATION_CHECKS=${WATCHDOG_MYSQL_REPLICATION_CHECKS:-n}
- WATCHDOG_VERBOSE=${WATCHDOG_VERBOSE:-n}
- IP_BY_DOCKER_API=${IP_BY_DOCKER_API:-0}
- CHECK_UNBOUND=${CHECK_UNBOUND:-1}
- EXTERNAL_CHECKS_THRESHOLD=${EXTERNAL_CHECKS_THRESHOLD:-1}
- NGINX_THRESHOLD=${NGINX_THRESHOLD:-5}
- UNBOUND_THRESHOLD=${UNBOUND_THRESHOLD:-5}
- REDIS_THRESHOLD=${REDIS_THRESHOLD:-5}
- MYSQL_THRESHOLD=${MYSQL_THRESHOLD:-5}
- MYSQL_REPLICATION_THRESHOLD=${MYSQL_REPLICATION_THRESHOLD:-1}
- SOGO_THRESHOLD=${SOGO_THRESHOLD:-3}
- POSTFIX_THRESHOLD=${POSTFIX_THRESHOLD:-8}
- POSTFIX_TLSPOL_THRESHOLD=${POSTFIX_TLSPOL_THRESHOLD:-8}
- CLAMD_THRESHOLD=${CLAMD_THRESHOLD:-15}
- DOVECOT_THRESHOLD=${DOVECOT_THRESHOLD:-12}
- DOVECOT_REPL_THRESHOLD=${DOVECOT_REPL_THRESHOLD:-20}
- PHPFPM_THRESHOLD=${PHPFPM_THRESHOLD:-5}
- RATELIMIT_THRESHOLD=${RATELIMIT_THRESHOLD:-1}
- FAIL2BAN_THRESHOLD=${FAIL2BAN_THRESHOLD:-1}
- ACME_THRESHOLD=${ACME_THRESHOLD:-1}
- RSPAMD_THRESHOLD=${RSPAMD_THRESHOLD:-5}
- OLEFY_THRESHOLD=${OLEFY_THRESHOLD:-5}
- MAILQ_THRESHOLD=${MAILQ_THRESHOLD:-20}
- MAILQ_CRIT=${MAILQ_CRIT:-30}
networks:
mailcow-network:
aliases:
- watchdog
dockerapi-mailcow:
image: ghcr.io/mailcow/dockerapi:2.11
security_opt:
- label=disable
restart: always
dns:
- DBROOT=${DBROOT}
- TZ=${TZ}
- /var/run/docker.sock:/var/run/docker.sock:ro
networks:
mailcow-network:
aliases:
- dockerapi
olefy-mailcow:
image: ghcr.io/mailcow/olefy:1.15
restart: always
- TZ=${TZ}
- OLEFY_BINDADDRESS=0.0.0.0
- OLEFY_BINDPORT=10055
- OLEFY_TMPDIR=/tmp
- OLEFY_PYTHON_PATH=/usr/bin/python3
- OLEFY_OLEVBA_PATH=/usr/bin/olevba
- OLEFY_LOGLVL=20
- OLEFY_MINLENGTH=500
- OLEFY_DEL_TMP=1
networks:
mailcow-network:
aliases:
- olefy
ofelia-mailcow:
image: mcuadros/ofelia:latest
restart: always
command: daemon --docker -f label=com.docker.compose.project=${COMPOSE_PROJECT_NAME}
- TZ=${TZ}
- COMPOSE_PROJECT_NAME=${COMPOSE_PROJECT_NAME}
depends_on:
- sogo-mailcow
- dovecot-mailcow
labels:
security_opt:
- label=disable
networks:
mailcow-network:
aliases:
- ofelia
networks:
mailcow-network:
driver: bridge
driver_opts:
com.docker.network.bridge.name: br-mailcow
enable_ipv6: ${ENABLE_IPV6:-true}
ipam:
driver: default
config:
- subnet: ${IPV4_NETWORK:-172.22.1}.0/24
- subnet: ${IPV6_NETWORK:-fd4d:6169:6c63:6f77::/64}
vmail-vol-1:
vmail-index-vol-1:
mysql-vol-1:
mysql-socket-vol-1:
redis-vol-1:
rspamd-vol-1:
postfix-vol-1:
crypt-vol-1:
sogo-web-vol-1:
clamd-db-vol-1:```
