Hi, I’m a bit of a beginner when it comes to self-hosting, so I’ve used the ISO version and am currently hosting it locally on my network. I’m not sure where to post this, but I have a few pieces of feedback and questions I’d like to ask.
Full English Translation - A few elements on the settings page are not translated into English. Have I missed a step, or is this the current setup?
User Membership Roles - Is it possible for admins to create roles and control access to modules installed by the admin? For example, allowing one user to have access to virtual machines while others do not. Is this possible without having to set up Active Directory (AD)?
Login Page - Is there a way to force a redirect to the login page before users can access the dashboard?
Global RDP Settings - Not sure if this is a limitation of Guacamole, but is there a way to set global settings for RDP VMs? For example, I would like to enable audio for all users without having to manually adjust settings for each individual user.
Different RDP Access for Different VMs - This is probably a technical limitation on my part, but is there a way to provide different RDP access to different VMs, instead of just the default Debian server (which I assume is the main host)? For example, if I have another server I want to access from the dashboard, would it be possible to have a menu display the available servers for Guacamole to RDP into, so users can choose the one they want to access? I’d also love to explore VDI if that’s even possible.
Storage Cap for Nextcloud Users - I might have missed this, but is there a way to limit the storage capacity per user on Nextcloud? Additionally, aside from expanding storage on the host VM, is there a way for Libre Workspace to detect unallocated storage and give users the option to expand it within the GUI? Also, is there a way to see which user is using the most storage?
Dashboard Customization - It would be great to have additional themes or customization options for the dashboard.
Is there a way I can donate to the developer?
Thank you for creating this application and making it free.
