BETA Release 26.1
Hello everybody!
Today I am thrilled to announce the very first official BETA version of Libre Workspace 26.1.
To do this, you can switch non-production systems to the “testing” branch.
You can do this by changing stable to testing inside the /etc/apt/sources.list.d/libre-workspace-stable.list and running a normal update afterwards.
This 26.1 version doesn’t bring any new features compared to 0.10.10; its aim is to guarantee that this version is our first full version, which we can recommend for everyone to install and use.
The BETA phase is planned to run until the 27th of January; the 28th of January is planned as the release day for Libre Workspace version 26.1.
You are welcome to report any bugs you find in this thread or at Issues - Libre_Workspace/libre-workspace - Codeberg.org
Thanks for helping Libre Workspace get its first real stable version. I am looking forward to seeing how this project evolves over time and “grows up” :slight_smile:
Cheers,
hab das mal gemacht, kann es sein, dass jetzt im Addon Center keinerlei Addons mehr angezeigt werden? Weil, bei mir ist das so…
Das Testing Repository hat noch keine Addons drinnen, kommt noch. Danke für die Erinnerung :slight_smile:
Die Addons sind nun auch im Testing Branch vorhanden :slight_smile:
Danke! Confirmed :slight_smile: Habe testweise Portainer deinistalliert und wieder installiert, alles gut. Bis auf das fehlende Icon bei Portainer, das muss man nach wie vor manuell hinzufügen.
