Addon: Paperless-ngx
Hi guys,
today I want to share the Addon Paperless-ngx, a document management system with ai sorting and ocr recognition.
It’s very easy to use. Download the .zip file and upload it in the addons section of Libre Workspace.
Then hit “install” at the modules section.
After few minutes you will find a new entry at the portal page.
The url will be paper.yourdomain.com.
At the time Paperless-ngx is not conncted to the central authentication system at Libre Workspace and will not share any users.
The default login for Paperless-ngx is: “admin” the Libre Workspace password of your administrator user.
Have fun using it!
If you have any further questions, please let me know.
paperlessngx.zip (9,9 KB)
Update : Now with SSO :slight_smile:
(German) Hier gehts zum Video der Entwicklung: https://youtu.be/3h1vV_B5ve0?si=pgsvS9n2t10nQ0Yt
whooo yeah, thank you.
one question, is it with tika & gotenberg to deal with .docx and .eml ?
Tika should be supported.
The official paperless ngx docker image is taken: https://hub.docker.com/r/paperlessngx/paperless-ngx
i think its optional, so its not includet.
https://paste.yunohost.org/eduquhucem.less
this might work with tika and gotenberg
I will have a look to it in time :slight_smile:
In dieser Version kann Paperless:
Signierte PDF’s, Libreoffice Dokumente, Worddokumente und Mails verarbeiten.
Ich weiß nicht wie man im Enviromentteil folgendes behandelt:
     USERMAP_UID: 1012
      USERMAP_GID: 100
      PAPERLESS_ADMIN_USER: THE-USER-You-Want
      PAPERLESS_ADMIN_PASSWORD: DEIN-Passwort-FÜR-DEN-USER_
hier die Compose:
networks:
  internal:
    external: false
  broker:
    image: redis:7
    restart: always
      -  ./redisdata:/data
    networks:
      - internal
  db:
    image: postgres:16
    restart: always
      - ./pgdata:/var/lib/postgresql/data
      POSTGRES_DB: paperless
      POSTGRES_USER: paperless
      POSTGRES_PASSWORD: paperless
      - 5433:5432
    networks:
      - internal
  webserver:
    image: paperlessngx/paperless-ngx:latest
    restart: always
    depends_on:
      - db
      - broker
      - gotenberg
      - tika
      - "13125:8000"
    healthcheck:
      test: ["CMD", "curl", "-fs", "-S", "--max-time", "2", "http://localhost:8000"]
      interval: 30s
      timeout: 10s
      retries: 5
      - ./data:/usr/src/paperless/data
      - ./media:/usr/src/paperless/media
      - ./export:/usr/src/paperless/export
      - ./consume:/usr/src/paperless/consume
      - ./scripts:/usr/src/paperless/scripts
      - ./paperless-ngx-postprocessor:/usr/src/paperless-ngx-postprocessor
      PAPERLESS_REDIS: redis://broker:6379
      PAPERLESS_DBHOST: db
      USERMAP_UID: 1012
      USERMAP_GID: 100
      PAPERLESS_TIME_ZONE: Europe/Berlin
      PAPERLESS_OCR_LANGUAGE: deu+eng
      PAPERLESS WEBSERVER WORKERS: 2
      PAPERLESS_OCR_USER_ARGS: '{"invalidate_digital_signatures": true}'
      PAPERLESS THREADS PER WORKER: 2
      PAPERLESS_FILENAME_FORMAT: '{created_year}-{created_month}-{created_day}-{correspondent}-{asn}'
#      PAPERLESS_POST_CONSUME_SCRIPT: /usr/src/paperless-ngx-postprocessor/post_consume_script.sh
      PAPERLESS_TIKA_ENABLED: 1
      PAPERLESS_TIKA_GOTENBERG_ENDPOINT: http://gotenberg:3000
      PAPERLESS_TIKA_ENDPOINT: http://tika:9998
      PNGX_POSTPROCESSOR_AUTH_TOKEN: cdc0aaaef0b55a51985f96635ecbacfc729d92f6
    networks:
       - internal
  gotenberg:
      image: docker.io/gotenberg/gotenberg:8.7
      restart: unless-stopped
        CHROMIUM_DISABLE_ROUTES: 1
      command:
        - "gotenberg"
        - "--chromium-disable-javascript=true"
        - "--chromium-allow-list=file:///tmp/.*"
      networks:
        - internal
  tika:
     image: ghcr.io/paperless-ngx/tika:latest
     networks:
       - internal
Kann das jemand mit mehr Ahnung als ich korrigieren?
Hi Juri,
meinem Verständnis nach brauchst Du keine der Variablen in der docker-compose.yaml Datei.
Aber für Dein Verständnis kann ich Dir folgendes sagen:
Um die richtigen Werte der UID (UserID) und der GID(GroupID) zu ermitteln, schaltest Du dich per SSH auf Deinen Server auf (systemv@ip-adresse) und gibst “id” ein. Dort stehen die Werte die Du brauchst z.B. uid=1000(systemv) gid=1000(systemv)
Beim ersten Anmelden vergibst Du normaler weise für den Nutzer “Administrator” ein Passwort.
Möchtest Du das vorher und vorallem anders festlegen dann gib bei ADMIN_USER: deinen_gewählten_Namen ein und auch bei ADMIN_PASSWORT: Dein_gewähltes_Passwort
Dann wären das dann deine Anmeldedaten.
Grüße
Der LinuxMintUser
Hi Juli,
ich habe mir die Sache noch einmal angeschaut. Du solltest Namen für Deine Container verwenden. Wenn die gesamte Sache intern auf einem Server läuft, brauchst Du keine extra Commandos für das Netzwerk angeben. Ich habe die alle mal aus gehasht. Andere unwichtige Sachen habe ich auch ausgehasht und die Ports mal angepasst:
  broker:
    image: redis:7
    container_name: paperless-redis
    restart: always
      -  ./redisdata:/data
    - 33679:3679
#    networks:
#      - internal
  db:
    image: postgres:16
    container_name: paperless-postgres
    restart: always
      - 35433:5432
#    networks:
#      - internal
  gotenberg:
      container_name: paperless-gotenberg
      restart: always
      - "33003:3000"
      command:
        - "gotenberg"
 #     networks:
 #       - internal
  tika:
     container_name: paperless-tika
     restart: always
      - "39998:9998"
 #    networks:
 #      - internal
  webserver:
    container_name: paperless-ngx
    restart: always
    depends_on:
      - db
      - broker
      - gotenberg
      - tika
      - "13125:8000"
#    healthcheck:
#      test: ["CMD", "curl", "-fs", "-S", "--max-time", "2", "http://localhost:8000"]
#      interval: 30s
#      timeout: 10s
#      retries: 5
      PAPERLESS_REDIS: redis://broker:36379
      PUID: 1000
      PGID: 1000
      USERMAP_UID: 1000
      USERMAP_GID: 1000
      PAPERLESS_ADMIN_USER: Administrator
      PAPERLESS_ADMIN_PASSWORD: geheimesPasswort
      PAPERLESS_TIKA_GOTENBERG_ENDPOINT: http://gotenberg:33003
      PAPERLESS_TIKA_ENDPOINT: http://tika:39998
      restart: always
#    networks:
#       - internal
#networks:
#  internal:
#    external: false
vielen vielen Dank,
das werde ich dann mal probieren und hoffentlich meinen lw-server nicht shreddern.
leider klappt das nicht. ich geb das erst mal auf, eventuell kommt das ja später mal.
Hallo juri,
nun das hat mir keine Ruhe gelassen und ich habe mir die Sache noch einmal in Ruhe angeschaut und eine lauffähige Version fertig geschrieben. Nicht schön und immer noch verbesserungswürdig, aber lauffähig :slight_smile:
  broker:
    image: docker.io/library/redis:7
    restart: always
      -  ./redisdata:/data
    - 6379:6379
  db:
    image: docker.io/library/postgres:16
    restart: always
      - 35433:5432
  webserver:
    image: ghcr.io/paperless-ngx/paperless-ngx:latest
    restart: always
    depends_on:
      - db
      - broker
      - gotenberg
      - tika
      - 13125:8000
#      - ./paperless-ngx-postprocessor:/usr/src/paperless-ngx-postprocessor
#     PUID: 1000
#     PGID: 1000
#     USERMAP_UID: 1000
#     USERMAP_GID: 1000
      PAPERLESS_ADMIN_PASSWORD: Passwort
#     PAPERLESS_OCR_USER_ARGS: '{"invalidate_digital_signatures": true}'
#     PAPERLESS THREADS PER WORKER: 2
#     PAPERLESS_FILENAME_FORMAT: '{created_year}-{created_month}-{created_day}-{correspondent}-{asn}'
#      PNGX_POSTPROCESSOR_AUTH_TOKEN: cdc0aaaef0b55a51985f96635ecbacfc729d92f6
      restart: always
  gotenberg:
      restart: always
      - 33003:3000
      command:
        - gotenberg
        - --chromium-disable-javascript=true
#        - "--chromium-allow-list=file:///tmp/.*"
  tika:
     restart: always
      - 39998:9998
Erstmal viel Spaß - ich werde die Sache noch optimieren und hübsch machen.
!!! Bitte nicht vergessen Benutzer,Passwort etc. anzupassen…
Grüße LinuxMintUser
großartig <3
hübsch und optimiert wird dann upgradable sein oder muss ich dann neu installieren?
vielen Dank
das wird aber gebraucht, um digital signierte PDF’s zu verarbeiten. der hash muss also wieder weg nehme ich an
um es sauber hinzukriegen müsstest Du es erst deinstallieren (LibreWorkspace Module)
dann löschen (unter Addon Verwaltung) und das Image völlig neu zusammenbauen…
ja das hab ich schon gemacht, hat ja eh nicht geklappt. wenn ich aber jetzt neu installiere und du danach alles “hübsch und optimiert” machst, muss ich dann nochmal neu installieren?
ja, einige Sachen waren für meine Tests erstmal irrelevant,
die PUID und GUID auch wieder rein nehmen
Aber wie gesagt, “schöner Wohnen” kommt später und alle Variablen werden wir dann in eine .env Datei schreiben.
Bis nächste Woche
Viel Spaß
LinuxMintUser
danke, ich freu mich
Hallo, ich habe paperlessngx mit der o.a. *.zip-Datei installiert. Leider erhalte ich auch nach längerem Warten einen Error 502. Die docker-compose.yml ist konfiguriert, der Caddy-Eintrag läuft auf den richtigen Port. Die OpenConnect-Einstellungen stimmen mit den OIDC-Einträgen überein. Lösche ich diese Einträge aus der docker-compose.yml, dann startet Paperless regulär, allerdings ohne sso. Was mache ich falsch?
Die Fehlermeldung: paper.XXX.de kann diese Anfrage momentan nicht verarbeiten.
Caddy-Eintrag;
paper.XXX.de {
#tls internal
reverse_proxy localhost:13125
(in der docker-compose.yml sind die Zeilen natürlich eingerückt)
paper.XXX.de ist via ping erreichbar
Habs gelöst, die Syntax hat nicht funktioniert. Habe die aus der Anleitung von authehtik genommen, das hat gepasst. Steht dort alles in einer Zeile, und der Eintrag “OAUTH_PKCE_ENABLED”: “True” ist weggelassen. Klappt prima!
